Jag har haft kontakt med Milesight support och fått följande från dom.
In summary, the overall process is as follows: On the IoT open platform, code is written to assign the values of certain UC300 fields to text variables and construct a JSON fields. This JSON fields is then sent to ChirpStack, where the encoder file parses the JSON into a hex command, which is subsequently transmitted to the DS3604.
For example, you need to write code to assign the values of certain UC300 fields to variables such as text_1, text_2, and text_3. Then, you construct a JSON and send it to ChirpStack. On ChirpStack, the encoder file parses the JSON into a hex command, which is then transmitted to the DS3604.
    "refresh_display": "yes",
    "template_1": {
        "text_1": "1",   // UC300 uploads the value of Modbus channel 1.
        "text_2": "2",   //UC300 uploads the value of Modbus channel 2.
        "text_3": "3"   //UC300 uploads the value of Modbus channel 3.
