unvacs Hej! Finns det integration mellan IoTOpen och IFTTT (If This Then That)? hur skulle det fungera? måste Node-RED vara emellan? /Mohammed
rejas Hello! As far as I know there is none. But it is an interesting case and is doable. A shim-server that sits between IFTTT and IoT Open should be quite easy to implement i guess.
