unvacs Hi, Is it going to work if I use an outdoor LoRaWAN sensor with indoor LoRaWAN gateway and vice versa? //Mohammed
rejas Yes, if it is called indoor and outdoor is only description of the encapsulation. There is no difference in the way the things communicate.
Jesper Just to fill in, some Indoor Lora-Gateways has smaller built-in antennas and might not have so good coverage from sensors thru walls. But there is no technical limitations between them as Marcus said.
