unvacs Hi I have tried to install "2021-11-01-IoTOpen-lite.img" on raspberry B 5, But I got a message that the operating system does not support Rasp 5. Is there any update image för Rasp 5? //Mohammed
Jesper Hey! It might be that the image is outdated since it was made in 2021. It should be possible to install using the script from @rejas posted here on a clean Raspbian install.
unvacs Hi Again zwaved wasn't installed by default when I have installed Rasoberry OS on Rasp Pi 5. I did the following as an extra step on manual which written by Marcus sudo apt install zwaved -y then I started the zwaved.service like sudo systemctl start zwaved@ttyUSB0.service --> if you have Z-stick version 7 and for verifying pa aux | grep zwaved /Mohammed
unvacs Problem: Zwaved run without error ● zwaved@ttyACM0.service - "Zwave daemon service" Loaded: loaded (/lib/systemd/system/zwaved@.service; static) Active: active (running) since Fri 2024-04-19 14:58:53 CEST; 7min ago Main PID: 1056 (zwaved) Tasks: 7 (limit: 9255) CPU: 6min 17.346s CGroup: /system.slice/system-zwaved.slice/zwaved@ttyACM0.service └─ 1056 /usr/bin/zwaved -N usb0 -D /dev/ttyACM0 -n /var/lib/iot-open/zwave/nodes -c /usr/lib/iot-open/zwave/config BUT Can not include or exclude any zwave sensor/actuator. Any tips?? /Mohammed
