tobiasjonsson Hello, do you have a decoder for the Yosensi Agribox? We are testing two of these from Jönköping so I would think it should be supported? Thanks! Tobias Jönsson
Jesper Hey, Yes, I also found it in the tech site. Note that decoder to use needs to be specified either in the network server with tags or as meta-data (lora_manager.decoder_name) on the device in the plattform when the device has been created.
tobiasjonsson Thanks for the link! I got it to work although with one sensor. Hopefully I can reproduce it for the second
fehe Hi, We are having the same sensor but seams to have the same issue. Could you explain what settings you made to make it to work?
tobiasjonsson Hello @fehe, to get IoT-Open to decode a Yosensi sensor you go to the device and add a metadata key with the name lora_manager.decoder_name and the value yosensi. Hopefully then IoT-Open decodes the payload and create functions with correct values.
