Hakan I need to do the downlink command in Chirpstack with uc 300 to reset Counter_1. Does anyone know how to do it?
Hakan I have solved the problem with the help of milesight. The downlink command is sent to the gateway's application port, which is port 85. The instruction to set the DI 1 counter to 0 is: 7e050b006001000000007e The instruction to set the DI 2 counter to 0 is: 7e050b006002000000007e Link to manual. https://resource.milesight-iot.com/Support/Jacob/How%20to%20Get%20the%20Downlink%20Commands%20of%20Milesight%20Sensors.pdf.
