Hello! Im having alot of issues installing IoT open on my rasperry pi 3b+, im following this guide
https://github.com/mrejas/rpi-edge-client.sh/blob/main/iotopen-lynx-edge-client.sh
and ive also tried https://forum.iotopen.se/d/534-install-iot-open-components-on-raspberry-pi
but nothing works. Below is the errors im encountering so far
Good:2 http://deb.debian.org/debian bookworm InRelease
Good:3 http://deb.debian.org/debian-security bookworm-security InRelease
Good:4 http://archive.raspberrypi.com/debian bookworm InRelease
Good:5 http://deb.debian.org/debian bookworm-updates InRelease
Reading:1 https://pkg.iotopen.se/apt bullseye InRelease
Error:1 https://pkg.iotopen.se/apt bullseye InRelease
Plaintext signed file is invalid, got 'NOSPLIT' (does the network require authentication?)
Reading package lists… Done
E: Failed to fetch http://pkg.iotopen.se/apt/dists/bullseye/InRelease Plaintext signed file is invalid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://pkg.iotopen.se/apt bullseye InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
IoT Open is trusted, Good.
Repositories already set up, Good.
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package iotopen-rt
E: Unable to locate package iotopen-edge
E: Unable to locate package scheduler
E: Unable to locate package iotopen-verify
iotopen.json exists. Good.
sudo: iotopen-verify: command not found
sudo: /etc/init.d/mosquitto: command not found
No idea how to fix them, and im wondering why it is such a huge problem to install a app on the rasperri 🙁
Would appreciate help! Thanks.
Hi Helge!
Can you please try it again now. We have regenerated the InRelease file in our repository. That might solve the problem.
Seems to work for me.
iot@iot-open:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 https://deb.nodesource.com/node_12.x buster InRelease [4584 B]
Get:4 https://pkg.iotopen.se/apt bullseye InRelease [7369 B]
Get:5 https://repo.mosquitto.org/debian buster InRelease [12.4 kB]
Fetched 24.4 kB in 3s (9559 B/s)
Reading package lists... Done
    rejas Awesome! It worked and i came further for now 🙂 Appreciate it alot! I´ll comment here if i face any other problems haha..
