NodeRED has different login for the Admin Web-UI and what the nodes used to connect to IoT Open. Nodes should still be connected and responsive even if you sign out of the Admin UI.
Depending on how you navigated to the NodeRED instance there might be a link with auto-login. In that case you have to go to the IoT Open web interface and click the link again. After that the Admin UI is logged in again.
