Hello! I have a problem with one of my Oyster3 sensors. It did work, I saw it in Chirpstack and everything was fine, but when/if I change some of the configuration on the sensor it lose connection to Chirpstack... Someone else that uses Oyster3 and Chirpstack that have seen the same problem?
Got help from an source that have been using Oyster3 for a while.
"When you configure an Oyster3 you have to specify the region under "Basic LoRaWAN " to ”EU868 [1.0.2B/3A + 1.1B]” "
Which I totally forgot. But now I have a solution 🙂
Great that you solved. Now we know! 😃
